Old 04-28-2019, 10:41 PM
lotec lotec is offline
Senior Member
Originally Posted by Turion View Post
lotec,
Why bother with all the electronics when you can get a coil to speed up under load simply by winding it correctly? You have several variables in your ideas you have not even worked out yet that will affect success. And NONE of it has been tested to see if it even works. Why not just do something we already KNOW works? If you want a no brain absolute solution to getting your coil right, and can't be bothered to build the one I have shown already working, just add a capacitor to a coil like they used to do in the good old days to increase its capacitance. A variable cap would be best. Adjust it util the coil speeds up under load. Done.
Thanks Turion,
When you put it that way, why not indeed. The easiest solution is often the best and I like easy. That will be one of the first things I try when I get up and running.
