Old 04-20-2019, 08:28 PM
Rakarskiy Rakarskiy is offline
Senior Member
The device of the compensated two-phase generator of the increased efficiency Russian patent RF 2317628
The disadvantage of existing synchronous machines is that the magnetic flux created by permanent magnets of the rotor poles crosses the conductors of the stator winding located in the grooves of the inner surface of the stator. In this case, the generated electrical power in the generator is equal to the required mechanical power supplied to the generator rotor (excluding energy losses in the stator and mechanical energy losses in the rotor).
In connection with the above, the efficiency of all existing synchronous generators is always less than one.
The technical result, to achieve which the present invention is directed, is to create simple in design two-phase electric generators with efficiency greater than one.
Figure 1 Figure 2
