Old 04-15-2019, 05:09 PM
bistander bistander is online now
Gold Member
The guy in the video is an idiot
Originally Posted by BroMikey View Post
Standard equations for calculating OVER UNITY that any Engineer
is using. Motor generator efficiency can be determined through the
measurements of mass rotation this weight.
Even a freshman engineering student realizes the need to use the pertinent and appropriate equations. It is meaningless to just pull out any old equations from a textbook and punch numbers into a calculator as this fellow in your video has done. A minimum level of understanding physics is needed.
He knows the mass of his rotor. The equation to find force from Mass. F = M * a. Acceleration? Just use the gravitational 9.81 m/s^2. (Which actually just yields the rotor weight). Now he has a force. He multiplies times the radius of the rotor. Bingo. He has a torque number, so he thinks. Find the next equation, power = torque * rotational velocity. Plug in a conversion of RPM to radians/second and he has 1799 watts. That's 2.4 hp. He uses that as output power from his motor to calculate efficiency. Nevermind that nothing is connected to the motor shaft, so motor output power is necessarily zero. Therefore efficiency is zero.
But apparently all it takes to convince you of OU is a video of something rotating and some flashing LEDs.
