Old 03-18-2019, 03:36 AM
BroMikey's Avatar
BroMikey BroMikey is offline
Platinum Member
Originally Posted by Turion View Post
I know you said that was a 12 wire coil, but that bobbin doesnít appear full. Do you remember how many feet of wire you had on it? It isnít putting out the voltage I would expect, but you are running that motor on 12 volts, right? So when it drops down to between one and two amps input your watts in would be 1.5-2 amps x 12 volts or between 18-24 watts input, with an output of how many volts at how many amps?
My coil was from junk wire but it waas a great first try at 24 strand
175feet each of #29 wire. It wire is to small to get good amps out but
if you are looking for high voltage it is great. cept the wire started breaking
down cause it is only rated at 600v. I ran 800v plus thru it, didn't know
the thin wire with so many strands would run up that high, but now I do.
4200 feet total but speed up came at 8 strands on up, the more I used
the faster it will go.
I tried to tell you Bi was stubborn and unwilling to learn new tricks.
He is a closed door i think with a response like that last one. Crooked coils?
or trapezoid? Excuse me...........
