Old 03-17-2019, 11:07 PM
Turion's Avatar
Turion Turion is online now
Platinum Member
Coil
I know you said that was a 12 wire coil, but that bobbin doesn’t appear full. Do you remember how many feet of wire you had on it? It isn’t putting out the voltage I would expect, but you are running that motor on 12 volts, right? So when it drops down to between one and two amps input your watts in would be 1.5-2 amps x 12 volts or between 18-24 watts input, with an output of how many volts at how many amps?
"I aim to misbehave" Malcolm Reynolds
"Try Not! Do or do not. There is no 'Try' ". Yoda
