Old 02-10-2019, 12:59 AM
altrez's Avatar
altrez altrez is offline
Silver Member
Originally Posted by Turion View Post
altrez,
How you start depends on what you are trying to do. With two fully charged batteries and a third battery fully charged your potential difference is going to remain constant for longer because it is harder to charge a fully charged battery. But you are also throwing power away trying to overcome the resistance in the fully charged battery and charge it. With a dead third battery the potential difference is high to begin with but that drops as the primaries lose charge and battery 3 charges. Both will teach you things, but until you add s boost module and a pulsing circuit of some kind, either mechanical like Matt’s motor or digital like an Arduino running a 555 timer, you will never see the real potential of this system.
Hello Dave,
Thank you for the input. I do agree you need to add the boost module and Matt's motor / pulse circuit. My goal for this test is to start with the most basic of setups. And when I say basic I am talking 3 battery's and a controlled load.
I am working on a PDF that has everything from the start of this over 10 years ago to the current builds. I felt like the best place to start this documentation was with the simple 3 battery swap and go from there.
I know it works however I have never fully documented it in great detail. So I have ordered another data logger and another DC load tester plus four new 7AH battery's.
I will post all of my tests and a link on dropbox to the pdf.
-Altrez
