Old 02-06-2019, 10:56 PM
soundiceuk's Avatar
soundiceuk soundiceuk is offline
Gold Member
This is how my thoughts are settled:
If you want to build the Tesla motor use the pump because it is its opposite.
If you want to build the Tesla turbine use the Mk1 compressor 1,061,142 or Mk2 compressor 179,043 as they are the opposite.
The first machine on each of these is one side of the vortex, the other is the opposite.
The turbine turns heat into cold using centripetal force and the compressor turns cold into hot using centrifugal force.
The motor turns heat into radial pressure (torque) using centripetal force and the pump amplifies the air flow ability because it is adding the centrifugal force to the radial pressure.
