Old 01-28-2019, 02:13 AM
Sawt2's Avatar
Sawt2 Sawt2 is online now
Senior Member
Originally Posted by axxelxavier View Post
About booster, I thought there must be a voltage difference between in and out, in order to work properly. Today I've learned I was wrong, so a new test began.
About my inverter, is is 300 watt inverter, nothing special, except it's working between 9,6 - 15 volts, so I hooked up to my setup the booster set to 14,7 volt on output.
I have the data from previous test, so the differences should be visible from the very first run.
Best regards,
Teodor
Great, I hope your experiments go well for you.
