Old 01-27-2019, 08:44 PM
ilandtan's Avatar
ilandtan ilandtan is offline
Senior Member
Originally Posted by med.3012 View Post
@ilandtan
hello
the most important thing is the amplification factors, any coil or capacitor or whatever combination if there's no increased oscillation when the system is isolated from excitation / power source it's most likely the system can't produce such effect ... at least there's no huge gain as described by Don Smith
So I think that's one problem you have with an EBTC, if you make both both plates the same length, you are gaining no voltage step up or in the reverse step down. I guess it implies that it might be used best as an isolation transformer if you never join the plates, and leave a capacitive coupling. But where Don takes a voltage and makes few a few L1 windings drive many windings in the L2. The free transformation is not gained.
