Old 01-27-2019, 12:39 PM
Sawt2's Avatar
Sawt2 Sawt2 is online now
Senior Member
Originally Posted by axxelxavier View Post
Problem is that differential voltage is @14,5 volt in the beginning, and it's dropping to almost 9 volt in the end, so I don't think a normal booster would work for my 12 volt load.
It should be easier if my load voltage is on 24 volts, but my inverter is working on 12 volts... I will try later the modified motor setup on 24 volts, but after I will find a way to cut the big noise.
So, any suggestion? I want to try again with the inverter and booster, but what setup to choose? 3BGS with booster (I am not quite sure, though, if it will work, because of the big voltage in the beginning, or the setup with 2 batteries, who need booster to work?
Which should be the most efficient?
Best regards,
Teodor
Not sure what kind of inverter you have, most of the ones I have used over the years can handle up 15-16 volts then automatically shuts off around 10-10.5 volts. Most of the boost modules allow you to adjust the voltage, so you could adjust it so ithe initial differential doesn't exceed your inverter's upper limit.
