Old 12-15-2018, 11:17 PM
luc2010 luc2010 is offline
Member
Originally Posted by ilandtan View Post
That seems like a curveball right away. What do you mean dead; Does that mean acceptably discharged, or discharged beyond recommended recovery levels? I'm not an expert on battery charging, but I can give my useless advice.
A battery is a chemical device, so when you say it's dead, your telling me something is failing in the battery's ability to retain charge. Depending on the makeup of the plates, it's sulfation, the specific gravity of the electrolytes all contribute to the battery capacity, which is usually reflected by the voltage if all the baseline levels of the reaction are possible. However, you can't use voltage alone as the indicator of how many amps it can produce over a specified time.
If you take a brand new AGM battery, I think it will be above 14V, but a used one will charge to somewhere around 13.5V. There are sites that have all this information, but the fact is that it's better to have a "smart" charger, because it varies the charge rate by where the battery in its charge leve.. i.e., bulk, absorption, and float. If you are leaving it on 1.28A charge rate, that is a low rate, but you can't leave it indefinitely because it will cook the battery.
I have heard that radiant charges destroy batteries and make them more like capacitors, which we know doesn't work the same way as a battery. If you are using capacitors to charge a battery you can deliver high bursts of currents, but if you deliver too much it can damage the components. Heat is bad for AGMs, I've read. I recently bought a 5aHr battery and solar charged it with a 15W panel, in a month the battery slowly lost capacity because I had it out in the sun charging. I measured the voltage and everything worked as described, but the battery sides started to warp, and my charge controller started pulsing the load after an hour.
If the battery is "bad" it could mean different things so. I have probably given as much useless information as anyone can tolerate. You might ask Turion, he breaths batteries because his 3B device revolves upon the charging of batteries.
Hello ilandtan,
Thank you for taking the time to post, i am just trying to understand the battery charging process
as we know, we have
1-Constant voltage charger ''the standard method''
2-Constant current charger
3-Multistage constant current / voltage charger
its advantages and its disavantages thats need to be compared?
my guess,
for the last stage we must stop the voltage to 15vor even higher?
from 14v to 16v?
i need a sign to finish the process?
always, open to hear and try new ideas!!
back to work!
Thanks again for sharing
luc2010
