Old 10-30-2018, 09:27 AM
Iamnuts Iamnuts is offline
Banned
Wikipedia.
Entropy is conserved for a reversible process. A reversible process is one that does not deviate from thermodynamic equilibrium, while producing the maximum work. Any process which happens quickly enough to deviate from thermal equilibrium cannot be reversible. In these cases energy is lost to heat, total entropy increases, and the potential for maximum work to be done in the transition is also lost. More specifically, total entropy is conserved in a reversible process and not conserved in an irreversible process.[6] For example, in the Carnot cycle, while the heat flow from the hot reservoir to the cold reservoir represents an increase in entropy, the work output, if reversibly and perfectly stored in some energy storage mechanism, represents a decrease in entropy that could be used to operate the heat engine in reverse and return to the previous state, thus the total entropy change is still zero at all times if the entire process is reversible. An irreversible process increases entropy.[7]
