Old 10-05-2018, 01:50 PM
spacecase0's Avatar
spacecase0 spacecase0 is online now
Senior Member
Originally Posted by ilandtan View Post
Anybody feel free to correct me:A Kacher is similar to Slayer circuit, basically a solid state Tesla coil where feedback from L2 drives the base of a PNP or NPN transistor, which sources or sinks L1. The advantage of the Kacher/slayer SSTC is that resonance self adjusts so an idiot can build it and make it work. A true "Tesla coil"(because he had many variations) usually associated with lighting discharges, uses rotary or magnetically quenched spark gaps driving tuned LC tank circuits for L1, and L2 has to be tuned to L1 and loosely coupled but not directly connected to each other. To function, the design parameters have to be well thought through.
Whereas Slayer's are easy and cheap to build.
Again, I must point out Alexey's note about the difficulty tuning the system. So without some sort of system goal, separate functioning sub systems may be put together without success.
all the spark gap and tuning to get a tesla coil to do what it should is the old way to do it, and if that is all you have, then it does work.
but we have some very fancy tools now,
I would drive the primary direct with transistors that is driven by an arbitrary wave form generator.
you can easily set any detail you want that way.
but Alexey does not show a spark gap, so it is likely just a sine wave with nothing special going on at all.
