Ya there is something wrong with that Your current should stay about the same all way across the board. I usually run:
12 v 2800 rpms about 1.2 amp
24 v 5200 rpms 1.3 amp
ect...
You may want to check for short to the stator, or you may need to adjust the back plate beyond where the magnets stop the bolts. So you have to use clamps for temporary.
Last check to make sure the commutator sections are not narrower than the brush's. If thats the case you'll have top use 2 for off period.
Dip you bearings in light weight oil, sometimes factory ones are sticky.
I am leaning towards the short because of the current behavior.
Keep me posted.
Matt
ADD BROMIKEY TO YOUR IGNORE LIST He is a saboteur bent on the systematic distraction of every good topic on this forum and since he has been here most working threads have shut down. He is the enemy. If you have blocked him already add this to your signature and encourage others to block him as well. His onslaught of rambling in large text and his constant attempts to misinform at the excuse of being stupid should no longer be tolerated.
USER CP/Ignore list.
