Old 08-08-2018, 07:32 AM
Aaron's Avatar
Aaron Aaron is offline
Co-Founder & Moderator
Arrow Hidden Dance - Zero Force Motor Part 2 by Yaro Stanchak
At the 2018 Energy Science & Technology Conference, more revelations are disclosed about the last one year of experiments with the Zero Force Motor.
Within this follow up presentation, you will find all the specs, which should be considered a standard built for more experiments to get start with. It works and has already been proven out by Yaro Stanchak and James McDonald.
Yaro also shares the differences in more detail on attractive vs repulsive mode and how this looks diagramatically so the viewer can benefit from these findings. A thorough walkthrough on the Zero Force Motor's timing characteristics of the magnet's geometry in relation to the coil geometry is covered. This is very important and cannot be stated enough - timing is cruicial and can make or break your results.
Keep in mind this is a developmental process and there are no free energy claims. It is a novel motor with unique aspects that have not been used or exploited in conventional motors and bit by bit, the potential of what this machine is capable of is slowly revealing itself.
Pay close attention to the date in the table presented by Yaro. You may find there is more than meets the eye. And you will definitely see that at certain RPMs, which may idicate some resonant points that you will see the Hidden Dance happening within the macine as Yaro shows on the scope.
There is also a difference in the characteristics of how the motor operates in relation to its waveforms that are measurable if the ZFM is running on a battery compared to a linear current power supply. In other words, there appears to be advantages to running it on a battery compared to a power supply. Professor Robert Haralick during questions points out a very plausible reason for this and that is that when running, the ZFM is producing longitudinal waves that are accepted by the battery(s) but the linear amp power supply cannot.
This would be completely consistent with John Bedini's experience over the years with experiments on the Bedini SG when running on and charging batteries, which have shown unusual input vs output ratios and most of this disappears when running these machines on conventional power supplies. It has been stated over the years that the battery is very important as part of the open system and once again, these ZFM experiments shown by Yaro seem to indicate the same results.
Here are a few of the subjects that Yaro will show in this presentation:
  • Introduction and Brief Review Of Zero Force Motor Design and Operation
  • ZFM Timing and Firing Duration with Coil Voltages
  • ZFM Operational Characteristics; RPM, Amps & Efficiency
  • Review of O-Scope Wave Forms for Voltage and Amperage
  • Hidden Dance
  • Ron Cole ZFM Variant LCF or Linear Counter Field
Enough! Time to get back to the next round of ZFM experiments...
Zero Force Motor by Yaro Stanchak
Get 25% off with this coupon for a limited time: ZFM25
