Old 08-07-2018, 11:51 AM
citfta's Avatar
citfta citfta is online now
Gold Member
Okay.
Let's see if this will work for you. The following is not code. It is just a description of what the code should do. I am not that familiar with the code for Arduino. I do most all of my coding for Picaxe.
Beginning of program.
Read battery A
Read battery B
If A>B then go to loop A else go to loop B
Loop A
Pause 30 seconds
Read battery A
If battery A < low set point then go to loop B else return to loop A
Loop B
Pause 30 seconds
Read battery B
If battery B< low set point then go to loop A else return to loop B
I hope this is enough info to help you solve your problem.
Carroll
Just because someone disagrees with you does NOT make them your enemy. We can disagree without attacking someone. This means YOU especially BroMikey.
