Old 07-29-2018, 12:11 PM
Matthew Jones's Avatar
Matthew Jones Matthew Jones is offline
Platinum Member
https://www.youtube.com/playlist?lis...7WsknDG4439vV3
Thats the instructions in case you didn't have them. You just need wire. I wanna say 600ft of 24 awg will do the motor. 3 strands per winding. Can't remember exactly how much it takes. Some of the motors will take a skate board bearing.
https://www.amazon.com/Ceramic-Beari...563J3TZH9KE6Y2
If you have set of calipers you can measure the inside spots for bearings see if the ceramic will fit, Or you can just buy a set of regular bearings. The stock bearing aren't great.
You might want to be able to tune past the screws so some thing to clamps the motor together from end to end. I didn't do this except to test and then I built a new brush plate that mounted on the back with the adjustment prebuilt into it, but I gotta CNC to make those things, not so easy without it.
I can't think of anything else.
**Added this.. You may get extra wire in case your first attempt fails. Its not an uncommon thing. Better to have wire and not need it .....
Matt
ADD BROMIKEY TO YOUR IGNORE LIST He is a saboteur bent on the systematic distraction of every good topic on this forum and since he has been here most working threads have shut down. He is the enemy. If you have blocked him already add this to your signature and encourage others to block him as well. His onslaught of rambling in large text and his constant attempts to misinform at the excuse of being stupid should no longer be tolerated.
USER CP/Ignore list.
