Thread: Eric Dollard
Old 06-23-2018, 11:43 PM
Macak's Avatar
Macak Macak is offline
Junior Member
Cosmic Induction Generator
Some recent works with resonant transformers built for Eric's Cosmic Induction Generator.
First series: The center field between the two conjugate wound transformer secondaries is AM modulated, exposed to a burnt out 500 watt bulb creating the Aurora plasma mist. About 150 watts excitation at 1900 kHz.
Second series: Single transformer, AM modulated musical plasma discharge. Bach on a spark. Description below.
Macak is back!
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Video below: Music from a plasma discharge. There is NO speaker in this video projecting the sound. The sound is being projected from the plasma arc discharge displacing the air as it pulsates to the audio frequiencies. The arc is being generated by an amplitude modulated radio frequency signal (1900KHZ) from a radio transmitter at a power level of approximently 400 watts. The device shown creating the arc is a quarter wave resonant transformer (Telsa Coil) in telluric mode with the lower terminal of the transformer's secondary connected to earth. Design form factor is by Eric Dollard N6KPH and proportioned and fabricated by Bruce Gavin KD1MW.
Recording of video and audio was done with a Canon EOS M camera. Only the built in microphone of the camera was used to record the sound. Note the sharp pointed tips from the plasma brush discharge when the camera finally focuses. This is an organic shape that can be found in many natural conditions. Audio chain was limited to just the narrow bandwidth of the Yaesu FT990's AM passband. The bright light that appeared for a moment was a small florescent tube reacting to the high magneto dielectric field surrounding the plasma discharge.
