one more though...
Dear Peter, Lighty, and all
I would like to add something to my last message and am curious to hear your opinion.
In my understanding the universe also is a universe of frequencies (broad band of frequencies). Each element is a frequency occupying a band width of space. Groups or combinations of elements can, as a unit, cover a broader band width of space.
The atom is a manifestation and is both positive and negative in character; therefore, space also has two basic properties that is, positive and negative.
Atom energy, or any other energy derived from changing the form or state of physical material, is energy taken from atomic structure.
With the right theory it is possible to tap energy in abundance from the driver of the atom (space energy) without taking it from atomic structure.
Atomic power with its penalty of contamination is not necessary, as the basic atomic energy can be tapped before it is material substance. Then there are no contaminations or harmful side effects, because nothing is destroyed and because the energy is only used, even as the wind is used by the windmill.
Radiant energy in my opinion is a result of distorted and nonlinear space and energy in common is a result of distorted space.
As example:
Magnetism is a distortion of space, a distortion within the atomic structure of the magnet material or copper coil which extends into the space surrounding it.
As an illustration, we consider an undistorted area of space before us. We move an activated magnet into this area of space and the result is that this previously undistorted and linear space is now. That is, two poles exist in relation to the magnet; an N pole and an S pole.
At the N pole we have a lack of S pole and at the S pole we have a lack of N pole. Or, at each end of the magnet, we have a lack of balanced space. In other words, distorted space, (a low pressure area) now exists at each pole.
Any non-polarized material within the band width of magnetism and electricity
(a paramagnetic material) will migrate to the low pressure area at either pole, while a polarized object (another magnet) will demonstrate the law of opposites attracting and similars repelling each other. The above theory of expansion and/or contraction holds true as cause of magnetism in all types of permanent magnets or electromagnets.
An inductive collapse of a coil, the so-called collapsing field could now be described as space returning back to linearity with a slap. That is the positive and the negative closing in from opposite directions and filling a rapidly diminishing area and then suddenly coming together; perhaps even bringing about a slight crossing of bands, or a short circuit of electric space which would be like a miniature bolt of lightning.
The collapsing field of an electromagnet is a distortion of ether/vacuum space which is elastic in his property and cause of the resulting mono-polar electrostatic charge.
In this way it is possible to tap energy in abundance from the driver of the atom (space energy) without taking it from atomic structure. This is why I like to describe the atom like a cosmic energy windmill.
Best of greetings,
Shad
