Old 05-24-2018, 04:05 PM
dyetalon's Avatar
dyetalon dyetalon is offline
Senior Member
Originally Posted by bistander View Post
Hi dyetalon,
Yes you mentioned your motor earlier and I took a quick read of the patent application documents.
In the typical motor, be it AC, DC, PM, wound field, brushless, or brush commutated, like the graphic, the Lorentz forces are tangential to the axis of rotation. There are no Lorentz forces acting in the axial direction.
All magnetic fields are dipole. It is impossible to get around the nature of the dipole magnetic field. So the motor shown above uses dipole fields and is balanced.
I would like to understand what you envision as the magnetic paths in your motor design and why you feel it is superior to that as shown above. Please realize that the FEMM shown above could apply to a brushless design by electronically committing the armature making it the stationary member (stator) and having the magnet assembly rotate (as the rotor) making it an out-runner type BLDC or synchronous ACPM motor.
Start another thread. This should be focused on the cell.
I'm not going to debate the pros and cons of typical vs. transverse motor design here.
