Old 05-08-2018, 07:35 PM
roby_035 roby_035 is offline
Junior Member
Originally Posted by clarence View Post
Liable,
Seems the protective covering was also torn away and damaged.
needs to be replaced by protective covering before attempting to
wind new turns.
Also between layers of new winds cover the layers as you go with 3/4 inch
wide beige color masking tape.
It makes it easier on your eyes to count the number of new turns in each new layer.
It takes 330 turns of # 20 AWG Magnetic wire. Approx 6" for each turn X 330 turns equals 1980 inches divided by 12 inches equals 165 feet of wire
needed.
Get a 200 foot small spool to work with as it will need to be small enough to pass through the center of the core for each turn.
Hope this helps.
Clarence
Clarence
The 330 winding primary windings go in both toroids in the same direction?
Or one toroid is clockwise and the other is counter-clockwise?
Thanks ROBY
ROY
