  #19 (permalink)
Old 10-03-2008, 11:53 PM
Christine G.'s Avatar
Christine G. Christine G. is offline
Member
Breathing exercises
Originally Posted by Aaron View Post
For the last 13 years, I have been practicing various breathing methods to develop not only full lung capacity but also to cultivate Qi (life force energy) to a high potential.
No matter what breathing method you use, there are a few things you can incorporate into almost any method to increase the effectiveness of the energetic part of breathing.
A few things will be referenced.
The DAN TIEN in Chinese is the "Sea of Qi", which is the main quantum potential reservoir located about 3-4 finger widths below the belly button and inwards sitting in front of the spine. About 80% of the life force reserves sit there and about 20% is potentiating the "electrical" activity of the body.
LAO GONG points on the palm are known as the "Hard Working Points". You can find yours by making a fist and put finger from your other hand where the middle and ring finger nails are touching the palm. These points are on both palms and is the main energy point on the hand. There is also a minor chakra there as there are other minor chakra points at the knees, elbows, ankles and feet, etc...
QI (pronounded CHEE) is the Chinese word for spirit or the life force energy. Japanese is Ki, Indian is Prana, in Christian thought it is the "Breath of Life" from God. There are many names for this life force potential. It it composed of virtual photon potential, which is a quantum potential that fills all time/space. Conscious intention can and does direct the movement of this potential.
The below exercise should be done daily 1-3 times per day for 3 months straight without moving on. The purpose is to channel QI in one direction filling and expanding the capacity of the DAN TIEN. It is like installing a larger energy engine in your body and this will also benefit your ability to project stronger thoughts for manifestation.
1. Before starting, get into a comfortable sitting or standing position.
2. Keep the mouth closed on this part. Take the left index finger and plug the left nostril. Inhale into the right nostril while visualizing that you are breathing in pure white light and breath this pure white light down your chest, past your belly button and into the DAN TIEN. While keeping the left nostril closed breath the white light out of the right nostril. Do this 8 times. Now take the right index finger and plug the right nostril. Visualize breathing in white light into the left nostril to the DAN TIEN and back out 8 times.
3. Swirl the tongue clockwise about 40 times making sure the tongue rubs the roof of the mouth vigorously. Then swirl the tongue about 40 times counterclockwise doing the same.
4. Rub the LAO GONG points vigorously for 30 seconds to a minute to generate good heat.
5. If you are a woman, place your right palm and its LAO GONG point directly under the belly button 3-4 finger widths below. Place the left LAO GONG point on top of the right hand. For men, place the left on the belly and the right on top of the left.
6. Every time you breathe in through the nose, make sure the mouth is closed and the tip of the tongue is firmly pressing on the roof of the mouth. Breath in pure white light into the nose and down to the DAN TIEN. Focus on making this a long, slow, deep in breath. Do whatever is comfortable and don't strain.
7. Every time you breath out, drop your tongue and slightly open your lips and blow the air out slowly so that a feather wouldn't even move from your out breath. After the full in breath, drop the tongue and simply blow the air out slowly without visualizing anything leaving the DAN TIEN.
Continue to do the #6 and #7 in and out breathing with this method only focusing on channeling pure white light into the DAN TIEN but nothing leaving the DAN TIEN. Do this 1-3 times daily. Especially, do this while laying on the back and going to sleep.
You can picture the DAN TIEN expanding and becoming brighter and brighter with pure white light. Do not intend for the potential to move anywhere because it can fizzle it all out if it isn't cultivated to a high enough capacity yet and you will feel more drained than without doing this exercise. It knows where to go by itself so just let it do it's own thing.
After about 90 days, then it is time to move on to the Small Universe Breathing for about 90 days and then the Large Universe Breathing from then on.
Aaron, how many times do you do the in and out breathing, focusing on channeling pure white light into the DAN TIEN but nothing leaving the DAN TIEN? Do you do this eight times?
