Old 04-21-2018, 11:04 PM
Ufopolitics's Avatar
Ufopolitics Ufopolitics is offline
Platinum Member
Originally Posted by ricards View Post
Hi UFO,
thanks for that detailed reply..
Hello Ricards, my pleasure.
I'm sure I have stated that light was deflected by the stream of electrons being deflected.. the effect was the light because the cause was the stream of electrons being deflected.. maybe you got confused?.
Ricards...above you are looking at electron-light deflections...when we are referring to FIELD-ELECTRON DEFLECTIONS.
Light is just "the Painting" of Electron Beam on the screen...so why dedicate so much time to light-electron relation?
Main issue here is that Magnetic Fields DEFLECT Electron Beams...that is WHY I spent half of my CRT PART 1 video going over history of how the CRT versus the development of TV, RADAR and ALL Visuals were developed based on Coils changing their Fields polarities...then reproducing IMAGES, SIGNALS on screen...just like Old CRT Scopes also did...comprende?
on north and south opposite spins... maybe I should refer you to your thread where you state that spin rotation is the same..
This was written on Ken's Book...Now I wonder...did you really read that book?...or you just got tired of his insults, hatred, etc...then shut it off or just went over "slightly" and not deeply enough...?
Yes, I know exactly that "phenomena" very well...still, poles are opposite spins if looked facing at your eyes.
Same as when we get a small motor running and look at its front shaft (where it connects) then look at its back end...same position...it gives us the "illusion" the shaft movement are opposite rotations...but we know that SOLID SHAFT can't do that.
you rotated the magnet that is why the spin that you are visualizing was the opposite...
Negative, just refer to the Small Motor running example I cited above...and do not move the motor body, leave it seating on the table...You just approach your face to the front of motor, look at your watch ...then approach your face to its back end, look again at your watch...what is your conclusion now?
this indicates that the gyroscopic action newman was potraying in his book (energy machine of joseph newman) was correct.. but unlike the model of ken, the vortex like in the poles are not present, but still the lines of force only have gyroscopic motion..
on the "Thing" and the "Theory".. I'm pretty sure you get what I mean.. (because you made fun of it).. if not I can explain further.
Thanks but No thanks!!!
I'm sorry UFO but a CRT scanline CANNOT perfectly Identify poles like you are claiming.. YOU are the one who identified it.
the Only way to know the Poles is to get a compass set to align to the Magnetic field of earth in which the baseline of "Poles" is set.
That is plain BS, Ricards!!
You approach a NORTH POLE to a CRT SCANLINE SCREEN and it HAPPENS TO TWIST in a COMPLETELY OPPOSITE WAY THAN A SOUTH POLE WOULD!!!
ANY MAGNET, ANY SHAPE FORM OR SIZE...WILL SHOW YOU THE SAME, EXACT POLARITY DIFFERENT DISTORTION.
Watch my Video below AGAIN...obviously you pay attention to what I have written and shown here same way as you said you have read Ken Wheeler's Book.
on the lines of force that you guys are dismissing..
I will not refer you to a "Iron Filing" method (that you hated so much, even though it didn't do anything to you.) instead, I will refer you to a ferocell experiment.
I do not "hate iron filings"...I hate who has promoted the FALSE IDEA that we are all looking at Magnetic Fields when we see those MUDDY, RUSTED, RANDOMLY DISPERSED CHUNKS OF STEEL.
They have fed Us all with those WRONG VIEWS OF MAGNETIC FIELDS FOR MORE THAN TWO CENTURIES.
And now, it is about time You ALL WAKE UP!!
http://www.ferrocell.us/references/o...Ferrocell.ppsx
that is a file you can get here references
on page 5 of that slide show you will see this.. (I have cropped the image in case you cant access the website.)
Attachment 20704
why do those ferrous compound aligning like a "Line"..
They align like a "line" because you are ZOOMING at the ferrocell Nano Particles alignment.
But if you get your eyes OFF THE ZOOM....then you will see PLAINLY CURVILINEAR SHAPES AROUND MAGNET...NOT STRAIGHT LINES.
what now is the difference of "Iron Filings" (which is micro) to ferrous compound (can be nano).. if they all just act like numerous tiny compasses?.
I will ask you...
What is the difference between a HUGE PILE OF CONCRETE PLUS SAND MIX...PLUS A HUGE CONTAINER OF WATER...VERSUS A FINISHED CONCRETE BUILDING WITH A BEAUTIFUL ARCHITECTURAL STRUCTURE?
A Ferrocell contain nano particles of ferromagnetic metals...BUT, THEY ARE SEPARATED IN A VISCOUS - TRANSPARENT-LIQUID ON WHAT IS CALLED A COLLOIDAL SUSPENSION STATE (Search Colloidal, learn it) which happens to ALLOW LIGHT TO GO THROUGH EVERY SINGLE SPACE BETWEEN THEM...FORMING A UNIFORM LIGHT SPECTRUM
Same way Magnetic Viewing Film does but Ferrocells are like HD (HIGHER DEFINITION) MEANS TO VIEW FIELDS.
and forgive me for judging you guys for your ferro+magnet+light experiment.. I apologize.
I will just ask, when you visualize the magnetic field on those experiment.. do you visualized the "Light" or the "Darkened" area?.. as the magnetic field?.
Let me ask you Ricards...Could you get a Couple of Bottles of Glass...cut with diamond blades the rear (bottom) of each ones...frame them with wire and add some legs to it...would they serve to be used as PRESCRIBED READING GLASSES?
Or simply...could you try to see trough their rough bottom glass just like you could see with a perfectly made, non distorted piece of glass?
Do you believe is the same result to "RANDOMLY SPRINKLE" Iron Filings around a Field...just like we "sprinkle grains" feeding pigeons or chickens...randomly...or to have a FERROCELL to view Fields?
Finally...we do not look at either dark or light areas...we look at the BIG PICTURE, THE FIELD SPECTRUM Created by the Light going through the EVENLY DISPERSED ALIGNMENT OF THOSE NANO PARTICLES...which happens that LENS can be POSITIONED AT DIFFERENT DISTANCES in order to AVOID Field DIRECT and STRONGER INFLUENCE...going spherically, 3D around Field.
I could use a simple comparison...PIXELS...HIGHER DEF versus LOW DEFINITION, what is it all about?
HD just have smaller sized divisions on screen (DOTS) which gives Us a much higher definition of IMAGES we see.
Now...if we all would get the SAME "IMAGE" whether using Iron Filings or Ferrocells...then why to argue about it right?
But it happens that NOPE, THEY BOTH DO NOT SHOW SAME IMAGES OF THE MAGNETIC FIELD.
Plus...it Happens that NOT ONLY FERROCELLS...But also COLOR CRT's PLUS MAGNETIC VIEW FILM SHOWS EXACTLY SAME FIELD SPECTRUM...What a "COINCIDENCE" UH?
Now, tell me what else could we get, what other technology...to see magnetic fields which portraits same shape as Iron Filings do?
Above I have cited THREE METHODS...All different...but same results.
Please watch video below...it would help visualize all I have written above.
Take care
