Thread: Bedini SG
Old 04-14-2018, 04:52 AM
2SeeMore 2SeeMore is offline
Member
Magnet spacing
Hi Aaron,
You mention that the (1" wide) magnets should be spaced around the rim 3" apart. None of the rim circumferences are multiples of 4 though (a 20" rim for instance has a circumference of 62.83" - theoretically allowing for 15.71 1" wide magnets with 3" between their nearest borders), so I'll either have to space the magnets a little closer together (using 16 in this case) or a little further apart (if I went with 15). Any advice about this? A preference for one or the other?
Also, I got the sense that the size of the rim isn't so important and picked up a 17" rim as it seemed better balanced. But...most comments in the book mention larger rims. Should I use a larger one?
