Old 04-06-2018, 06:39 AM
Kokomoj0's Avatar
Kokomoj0 Kokomoj0 is offline
Senior Member
Originally Posted by Buddhafollower View Post
Good day,
What i really don't understand is why do people use such high frequencies (example: 1860K cycles/second, 560kcycles/s etc.) when Dr.Tesla said very clearly that TMT works at frequencies from few to thousands of hertz. Actually, i think he said that the MT works at frequencies below 20KHz. I don't think that we nowadays have the true schematic diagram of the MT as Dr.Tesla intended it to be. What we have is the ''Apparatus for transmitting electrical energy'' patent No.1,119,732. That's all we have and this installation naturally won't work at frequencies below 20kHz. Even the way it is drawn shows that the frequency will be in the range of tens of kHz to few hundreds of kHz judging by the ratio of the resonator. But that installation is not the Magnifying Transmitter. It is yet another device for the transmission of electricity through the ground. Very useful indeed.
If you wanted to build one for massive power transfer you most likely would want to follow tesla in frequency and size etc. Most people are struggling with proof of concept and trying to comprehend what tesla did and how it works. For experimenters its much easier to get good results cheaply using higher freqs because you can make smaller less costly builds and get nearly identical results. At least the high current goes through the ground.
