Old 03-07-2018, 12:32 AM
mikrovolt mikrovolt is offline
Silver Member
Good point BroMikey, Both warm and a cold type energy flows
where being discovered and the crystal cells were cold however
Back when Aaron was working on Ainslie hybrid circuit it was common to use thermometer to see the
resistors warming and the battery level jump. I recall the ebook was called The Quantum Key.
I mention this warm, cold distinction because recently we were asked about what type amplifier
should we be using. I believe the push-pull AB type, the cascode having miller effect
AB using either the negative or the positive now. later we will use both.
For example small fusion reactor for space travel sometimes needs heat other times cold ions.
Both reactors make a dipole. The wave guides form dog bone structure one side benefits from the other.
Even though flow is unidirectional on either side the push pull type forced oscillator will be useful for rapid aether replenishment.
The capacitors on either side seldom deplete otherwise reset restart. Principle being don't kill the dipole in switching.
In the future we can say Don't deplete the dipole capacitors in push pull operation.
