Old 03-06-2018, 03:15 PM
sampojo's Avatar
sampojo sampojo is offline
Senior Member
A request to Dingus for more explanation
Originally Posted by Dingus View Post
Atoms consume aether at a constant rate that varies depending on the element. Gravity is the movement of atoms from a high-pressure zone of aether to a low-pressure zone. Magnetic fields as well as the positions of the moon, sun & other large bodies with gravitational fields strong enough to affect earth will produce measurable changes in the pressure & direction of the flow of aether/gravity. The speed of light changes depending on the density of the medium it travels through, just like sound.
If Michelson & Morely had tested the speed of light every hour in a day for a month rather than once every six months, they would have understood why geocentrism is wrong.
Ok, you've planted the hook. Sagnac and Michelson Gale showed that the earth and the ether have a rotational velocity difference, which verifies interferometery works and that Michelson-Morely detected a nominal null value for translational velocity of the Earth around the sun or through the ether, making the conclusion that the earth is in the center of the universe plausible. Not familiar with the details of the data collection in those two experiments, I assume it may be similar to what you have proposed. It is understandable conclusion from those two experiments that ether is either rotating around a stationary earth at the rate of one day, or the earth is spinning at that rate. Can you offer more explanation about what you are saying?
Up, Up and Away
