Thread: Bedini Cigars
Old 11-25-2017, 03:39 PM
level level is offline
Senior Member
Originally Posted by Aaron View Post
Not that this really adds anything, but before the 2016 conference, if John had time, he was planning on demonstrating this with a high frequency version controlled with a pic chip. He only had time to present on the RPX.
It would have had the full rotation and it would have lit LEDs.
He was still excited about this project.
Hello Aaron. Thanks for that. That's interesting. Yes, a PIC or Arduino microcontroller would give you a lot more flexibility and control for doing all the switching, especially if you want to include rotating batteries in and out to give batteries a rest period.
LEDs consume only a small amount of power, and large AH rated batteries can power a few of them for a long time without dropping in voltage much, so I think it would probably be better if tests are done using some sort of load of at least a few Watts to test with. It really depends on the AH rating of the batteries you are testing with however. Choose something that will put some real load on the batteries that is in reasonable proportion to the AH rating of the batteries when testing, if you want see if the batteries can really stay charged up under load. It sounds like from past testing by a few people here that no one was able to keep the batteries from running down. Of course the smaller the load you have connected to the Tesla Switch the longer the batteries should maintain a charge, so I think to reasonably evaluate tests a person really needs to know the AH rating of the batteries used and the measured power consumption of the load in Watts that was being powered by the Tesla Switch. Without both of those pieces of info it's really hard to judge how well a Tesla Switch setup was performing, unless the Tesla Switch keeps the batteries fully charged up indefinitely while powering a reasonable load. If you are only pulsing current through a load at a very low frequency, then the load's power consumption will of course be less than when powered steady with pure DC.
As many people probably already know, you have to be careful with the new LED light bulbs because they often have a big Wattage rating listed on their packaging which is not the actual power consumption of the LED bulb, but the supposed equivalent Wattage power consumption for the same brightness that an old style bulb would consume. IMO, the best thing is to first connect your load you are going to use in your testing to a battery and measure the current it consumes when connected to a fully charged battery of the appropriate voltage for the load. That way you can see how much power the load really consumes when being powered at a specific voltage.
level
