Thread: Bedini Cigars
Old 11-23-2017, 09:21 PM
Matthew Jones's Avatar
Matthew Jones Matthew Jones is offline
Platinum Member
This all so funny. Go back and read "Use for the Tesla Switch"
Its huge and so many people contributed to it. There is a plethora of information and results. To watch a new group of people hash these things over is just hilarious. Course most of you are the new kinda researchers back then we actually built the thing before talking about it. Or built it while talking about it. LOL
There is no magic to it, it called math. By switching back and forth rapidly you build up a capacitive load on the plates of the battery and that load can then resonate. The largest problem being is the plates change so the value of the capacitance changes with them. This is not measurable and you have to be able to adjust on the fly to maintain a resonant state. Think Variable RLC resonants. Its hard but not impossible. But first you should be aware and able to create a simple resonant circuit, then be able to do that with a variable power supply like a battery, that changes voltage constantly, then you can start looking at this behavior from 4 batteries switching. Best results come at 700 - 900 hz.
But if you don't have the foundation correct your only going to see 4 batteries drop in power as if they were all wired up in parallel. And even if you manage to not burn up the system.
Diode protected mosfets will not get you there. IGBT's with no bypass diode exsit but are hard to find at a reasonable price. SSR's exist but rarely go faster than 500 hz.
I have had several run for many days without denting the initial voltage levels of the battery. I have never seen one not run down sooner or later.
I don't know why I waist my time ya'll won't build anything, your the new kinda researchers. LOL
Matt
ADD BROMIKEY TO YOUR IGNORE LIST He is a saboteur bent on the systematic distraction of every good topic on this forum and since he has been here most working threads have shut down. He is the enemy. If you have blocked him already add this to your signature and encourage others to block him as well. His onslaught of rambling in large text and his constant attempts to misinform at the excuse of being stupid should no longer be tolerated.
USER CP/Ignore list.
