Old 10-19-2017, 06:09 PM
gotoluc gotoluc is offline
Gold Member
Originally Posted by Turion View Post
Luc,
When you say you have followed what we have been sharing and then post a video that discredits our work using batteries we have said a thousand times will NOT work, what am I supposed to think, other than that you are NOT just a skeptic, which is COMPLETELY understandable, but a disinformation specialist?
The video you keep referring to was not related to your work. Don't know why you keep bringing it up or why you or Mat were so offended by it. Please point out anything in the video that refers it to your work.
If you can't find anything referring it to your work then stop using it to discredit me as it's not about what you guys shared.
If I post a video today of a system with four batteries running 600 watts of load between the positives, what does that prove? NOTHING! Any idiot can hook that system up and run it. And it will run for a while, even when hooked up INVORRECTLY, before there are significant losses enough to prove it doesn’t work. So how do you prove it works? You let it run for a month and THEN measure the batteries. How do I put THAT in a 3 minute video.
It's unrealistic to think a 3 minute video would prove anything. However, if you explain the devices main components, power source and what it can achieve in a said time then maybe it can be done in a 20 to 30 minute video without revealing your secret.
I do not care whether you believe me or not. I do not care whether you build this or not. What I object to is someone saying this doesn’t work when they have made no REAL attempt to actually replicate what we have shared.
Again, please post a reference where I say your device doesn't work.
If you can't which I know you can't then stop making false accusations.
I could name 20 people who have replicated it correctly and have seen that it works. At least to the extent that you get much longer runs than possible off the four batteries connected in parallel. I even know of a couple who figured out before I did what it takes to keep the third battery or batteries in that position charging faster than the primaries discharge, and for THAT I owe them.
I don't need 20 independent replications. Just 1 will do as long as the power calculations are done correctly.
Looking forward to it.
Luc
