Old 10-13-2017, 06:09 PM
dragon dragon is offline
Silver Member
Originally Posted by SkyWatcher View Post
Hi all, before even reading the recent replies, of course i didn't mean higher output than input.
I meant, we might be getting more power out from an external source, not associated to what we input.
So yes, i meant coefficient of performance, i just assumed you all knew that is what i meant.
peace love light
Well, take for example, the collapsing field of a coil, does that give us more than we input, not usually, though it gives us back some to use from the environment, external to what we input.
I think your logic with this is sound dragon and your original circuit is probably the best design to use, based on the low losses and multiple recycling passes.
Though dragon, you still didn't respond to what you thought the benefits of the charging battery might be, or how it compares to your 4 pass circuit.
To be honest Skywatcher I haven't tried that set up. Anything I might say about it would simply be speculation. There is no doubt in my mind it will work reasonably well. The extent of its performance would need to be measured and compared.
When time allows I'll be setting up a few different innovations you've brought to the table. Until I get caught up on some other projects I can only watch and drool over what others are doing...although I'm sluffing off a bit today - to many 16 hour days, my motivation level is a bit lacking today...
