Old 10-06-2017, 07:36 PM
SkyWatcher's Avatar
SkyWatcher SkyWatcher is offline
Gold Member
Hi all, here is a video showing dragons circuit variation in action.
The circuit with the single battery powering the boost converter and so being discharged and charged intermittently, while also powering a resistor bank load.
Here is circuits drawn by dragon, this video is based on the bottom circuit.
https://youtu.be/AI6Sir7ZL60
As you can see, the volt meter is showing the 12 volt tractor battery being discharged and charged.
The 30 watt-.5 ohm resistor bank heats up rather quickly.
The 12 volt battery resting voltage was 12.57 volts and recovers to that or just below after an hour or so.
I will test this variation some more, though i still feel the dual battery version might be more efficient, then the batteries can be swapped, we shall see.
peace love light
