Old 08-02-2017, 01:35 AM
Turion's Avatar
Turion Turion is offline
Gold Member
If you have a full capacitor on the high side, you CAN run it through the motor to empty capacitors in parallel on the low side, but you CANNOT then move those capacitors from the low side back to the high side and recycle that energy. It won't work because the capacitors you charged in parallel which now have (as an example) 12 volts each, cannot be put in SERIES to give you 24 volts on the high side. It doesn't work like that with capacitors. So with a group of caps you only get to use the potential difference ONCE.
