Old 06-26-2017, 03:47 AM
BroMikey's Avatar
BroMikey BroMikey is offline
Platinum Member
Originally Posted by Ufopolitics View Post
Guess it is part of the balancing process to sand-smooth the outer rotor steel laminates, meaning to lathe-cut-rectify the green epoxy so it runs smooth within stators right?
I have never seen a double ended rotor commutator. But now that I
have it seems like the idea here would be to feed one end power in
and the other end or the other commutator would be connected in a
way to power something. A sort of rotating input output motor-Gen.
I guess I just never saw one before. I'll bet you could have field day
running a 3 battery split pos system on each end
Is this design from 2014? Is there a self running machine? Or
are you still testing possibilities?
