Old 05-30-2017, 05:44 PM
Turion's Avatar
Turion Turion is offline
Gold Member
Thoughts
I have a light board that holds eighteen 300 watt bulbs with switches for each. AC switches don't work so well for 257 volts of D.C. Though!! Boom! They can be wired in series or parallel. I have been experimenting with that. When I connect one 300 watt bulb to a pair of coils, they light up, but the machine does not speed up under load. It doesn't speed up with two connected in parallel. It DOES speed up with three connected in parallel, but the light is so dim with 3 bulbs (900 watts of load) that you can't even tell they are on. I haven't measured the voltage output with that configuration. I guess I should. So I have lots of things to try to prove the output.
For me, the proof of success is in the data, and until I have voltage and amperage output UNDER LOAD to compare to input voltage and amperage, I won't be inviting anyone to replicate this machine as it is just too expensive. Right now I'm not entirely sure how much of the 257 open volts DC is REAL, as I haven't found a load that will use that much voltage.
"I aim to misbehave" Malcolm Reynolds
"Try Not! Do or do not. There is no 'Try' ". Yoda
