Old 05-22-2017, 07:56 PM
Gambeir's Avatar
Gambeir Gambeir is offline
Silver Member
Originally Posted by Allen Burgess View Post
Here's how it works:
Magnetic vortex wormhole generator
https://www.google.com/patents/US20030197093
ABSTRACT
This invention relates to a magnetic vortex generator which has the ability to generate negative mass and a negative spring constant which, according to Einstein's General Theory of Relativity, is required in order to create a stable wormhole between our space and hyperspace. Two separate, but electrically connected, toroidal coils of differing radii, carry magnetic flux in opposite directions about their common centerline. According to Maxwell's equation, this produces bucking electric fields along said centerline. Because the two solenoids have different radii, the parallel spring constant of both coils is negative. The negative mass together with the negative spring constant produce a real resonant frequency which can distort the spacetime curvature due to the creation of powerful spikes of negative mass. This phenomenon, similar to the common electrical thunderstorm, opens up a wormhole into hyperspace through which low-density hyperspace energy can enter into our dimension. This energy finds many application in new types of power supplies, inertia-less and mass-less spacecraft, vehicles that can travel light-years by moving out of dimension through hyperspace, surgery-less medical tables, cranes for lifting heavy objects, cold-welded crystals for crystal rotors, folding space waveguides, and electromagnetic field propulsion vehicles using highly relativistic fields.
Now if you look at the images from the folks over at Spacewarp on their science of Bruce Gernon's interupted journey, or accelerated one if you prefer, then there appears to be some support to this idea.
[url=http://www.spacewarpdynamicsllc.com/[/url]
https://static.wixstatic.com/media/0...3e3e9dd9c5.png
And another thing> Ya know how they are always saying these UFO's have strange hieroglyphics or writing on them. Well just look at what the spacewarp people have created. Now if that's working as
an antenna, and applied to the exterior of machines then I suppose most people would try to explain it as writing or some kind.
Bucking Gap Image located at:
https://www.overunityresearch.com/in...?topic=3107.75
