Old 05-20-2017, 05:02 AM
ET-Power's Avatar
ET-Power ET-Power is offline
Member
Originally Posted by Allen Burgess View Post
Take a look at this patent. Vortexing magnetic field on the horizontal plane:
Link to "Rotating Electrostatic Propulsion System":
https://www.google.com/patents/US200...wcAKQQ6AEIWDAH
BRIEF SUMMARY OF THE INVENTION
[0001]
The invention, which is the object of my present application, is a spacecraft propulsion system which develops a spacetime curvature tension utilizing a combination of a rotating radial electrostatic field and a fixed vertical electrostatic field. The two fields create a stress-energy Tzr gradient in the radially direction which is equal to force. The radial field is created on the side of a charged rotating cylinder on the underside of the hull. The vertical field is created by an annular charged ring concentric with the cylinder. Three rotating cylinders are located in a triangle on the bottom of the hull in order to produce a force in any direction in the horizontal plane.
I saw a TR3B in 2009/2010 leaving the Scientology Center in Hollywood, California.. it was only 10:30pm or so at night... It slowly hovered above the Scientology Complex and then like a streaking light in Star Wars/Trek, etc... it took a 90* angle and was off into space-time/transdimensional travel. It had an orange *PLASMA* glow from the bottom center.
I swear under penalty of perjury for forgoing facts are true.
"Rebellion to tyrants is obedience to God." - Benjamin Franklin + Thomas Jefferson
