Old 05-18-2017, 03:26 PM
Allen Burgess Allen Burgess is offline
Gold Member
Tr-3b
Take a look at this patent. Vortexing magnetic field on the horizontal plane:
Link to "Rotating Electrostatic Propulsion System":
https://www.google.com/patents/US200...wcAKQQ6AEIWDAH
BRIEF SUMMARY OF THE INVENTION
[0001]
The invention, which is the object of my present application, is a spacecraft propulsion system which develops a spacetime curvature tension utilizing a combination of a rotating radial electrostatic field and a fixed vertical electrostatic field. The two fields create a stress-energy Tzr gradient in the radially direction which is equal to force. The radial field is created on the side of a charged rotating cylinder on the underside of the hull. The vertical field is created by an annular charged ring concentric with the cylinder. Three rotating cylinders are located in a triangle on the bottom of the hull in order to produce a force in any direction in the horizontal plane.
