Old 05-05-2017, 12:56 PM
Allen Burgess Allen Burgess is offline
Gold Member
"A" vector lift
Jerry Bayles:
"The test torus was mounted at the end of a sensitive balance beam so that the opening in the center has the center axis vertical, or perpendicular to the Earth's surface. The torus center opening was void of conductors or other material. When the torus was energized with pulses of current, the torus rose into the air. When the current pulses were reversed in polarity, the torus rose again into the air. The A-Vector pointing up caused the torus to raise slightly more than when the A-Vector pointed down towards the Earth. When the torus was oriented so that the torus axis was horizontal with respect to the surface of the Earth, only a slight rise was noted with both polarities of toroid winding input pulses".
