Corona motor along with explanation of atmospheric electricity.
This post is a video of an experiment using atmospheric electricity
the rotating device is electrostatic and uses infinitesimal amounts of current.
Reference source is the book titled " Lectures on Physics. "
by professor Richard Feynman. Vol 2. p9 which is p113 pdf:
https://bayanbox.ir/view/58838319117...and-Matter.pdf
In the video note the plastic crate is used to keep works up off the ground because the charge will try to find a path to a ground.
I see some less successful experiments that use a table that might take a long time to charge or cause a leak. Also below the video are list of other related sources. Be careful of HV!
https://www.youtube.com/watch?v=2rVdEhyMR6A
ebay sells small HV converters that use 3V battery or solar cell in case
you don't have a drone copter and reel of wire the solar cell to HV.
see picture 9.1 b How could you rearrange the charge on the man
to lower the lines to have 900V at 1 meter ?
