GEM=Geometrical Electricity Multiplier
You just have to be multiplying AC electricity, when you only input one spark
= small amount of DC electricity that it takes to rotate a motor one single time,
+ get a return of 1000 cycles of AC electricity
These AC generators run free of most all torque, as they only need to generate one spark of DC current, to make this free energy technology self powered, + crank over your DC motor one time
This works on the simplicity of only having to pay the small amount of electricity, (massive voltage + only one spark of current) for the one single rotation of a DC motor with a large 100 cm circumference pulley attached. Then you take the 100 cm of moving belt, that comes from the one rotation of your 100 cm circumference pulley, and run it past 10 of the 1 cm circumference pulleys. This would multiply your # of rotations to 10 X 100 = 1000, and if you added AC generators to these 10 mini-pulleys you would gain a total of 1000 cycles of AC electricity.
These AC generators would run free of most any torque, as they are just winding up massive voltage,(which is what you need to crank over your DC motor=electrical pressure) as the only current that they need to generate is the one spark, or practically zero. You only need to generate one spark of current, because that is how much current that it takes to rotate your DC motor, with the 100 cm circumference pulley one single time. Of course you would also need 10 full wave bridge rectifiers, (4 diodes each) to convert your AC outputs back into your DC input.
you are trading one rotation of a 100 cm circumference pulley, (taking massive voltage) for 1000 rotations = 100 rotations each from 10 mini-pulleys with AC generators (creating massive voltage)
This is so simple that it just has to work.
It only takes one spark of DC current to rotate a DC motor one single time,
+ If you attach a 100 cm circumference pulley to this DC motor it will give you 100 cm
of moving belt Then, if you run this 100 cm of belt past 10 of these free running 1 cm circumference mini pulleys you would get 10 X 100 = 1000 rotations.
If you add 10 AC generators, one to each mini-pulley,
These 10 AC generators run torque free, as they only need to generate one spark of DC current,
which is practically zero, and practically zero current, times even massive voltage,
is still equal to practically zero.
