Old 12-16-2016, 07:41 AM
Excalibur's Avatar
Excalibur Excalibur is offline
Senior Member
Originally Posted by cornishscrimper View Post
Is it possible to convert most of the output into gas rather than liquid fuels ? Say with the correct catalysts etc ? Have read through cannot see a mention of it.Thinking about off grid set up and using gas (not gasoline) to run generators, gas fridges , cooking and gas water boilers etc.
Not that I've tried but yes, I'm convinced you could do this and without any catalyst. The method would be to reduce reflux chamber temperature thereby only allowing non-condensable gas to escape downstream. The product would be something along the lines of LPG/propane. Settling on a reflux temperature setting would be a case of trial and error but I'd start with water cooling perhaps thermo-syphoning to an overhead radiator.
