Old 05-16-2016, 12:49 PM
Allen Burgess Allen Burgess is offline
Gold Member
Originally Posted by spacecase0 View Post
ok, so are you going to build it ?
an alternative to using vacuum bearings is to use magnetic coupling (like they do for magnetic stirrers ) through your vacuum chamber
might cost less to do and be faster to build
@spacecase0,
The problem the magnetic coupling creates is the disruption of current through the axle. The rotating anode would need a seperate internal power connection with the detached bearings. Still a pretty good idea, not counting the drag.
We need someone to test the strength of the "Plasma Vortex" counter rotating magnetic field. Just twirling a piece of aluminum foil positioned in adjacency to the "Vortex" would act as a strong proof of concept.
I may need to buy and disassemble a used microwave for the magnetron ring magnets.
