Old 01-08-2016, 08:04 PM
bistander bistander is online now
Gold Member
Redi-line generator
Originally Posted by BroMikey View Post
Here is another magnet motor generator running.
Published on Feb 1, 2014
The purpose of this Self Looped Generator proof of concept project is to determine what happens when you take 12v dc components (12v battery and motor) that produce 120vac and plug in a Kill-A-Watt meter to a CFL bulb. Then with the same power produced by the motor, plug in a battery charger to recharge the same battery. Then take a drill to see what kind of a voltage drop occurs and if the battery voltage is either sustained or dropped. The results are pretty impressive as a portable setup without any external power from the power company or fumes.
The only thing remarkable about that is that someone could think there was free energy demonstrated. It is obviously an old Redi-Line motor/generator which has taken a serious hit. The bracket is broken, the faceplate is missing and it has been partially demagnetized. Besides the obvious reasons why self looping with a battery charger won't work, you can see his orange extension cord off to the right in one camera angle likely feeding his battery charger for his scam.
See this link for Redi-Line. Alternator Starter > Innovative Solutions > RediLine Generators
