Old 12-03-2015, 09:22 PM
Turion's Avatar
Turion Turion is offline
Gold Member
I bolted a flat metal strap to the back end of my "cheese grater" that has a hinge at one end so it can pivot toward the plastic rotor. It swings in and out. As you said, you have to move it in very slowly, but by stopping the grinder quite often, I can see when it is making contact all the way around the outside of the rotor. As soon as it is, I know the rotor is "round" and have a sanding pad I put in its place to "smooth" things out completely. Then I'm done.
Or, if you want to doit the way YOU did it without all the work and you have a few bucks.
Hub 1 2" Shaft Diameter with Keyway Meyer or Buyer Salt Spreader 36152 0202800 | eBay
"I aim to misbehave" Malcolm Reynolds
"Try Not! Do or do not. There is no 'Try' ". Yoda
