Old 11-27-2015, 03:49 AM
BroMikey's Avatar
BroMikey BroMikey is online now
Platinum Member
Originally Posted by bistander View Post
Look again at my post. There are no light bulbs in the videos.
Here Bi read this from Thane. Don't believe me.
Published on Jan 21, 2015
The ReGenX Generator Coil by Potential Difference Inc. is a new type of generator coil that has NO Armature Reaction / does not produce any electromagnetic resistance when a load is applied and delivers 600% more output power than a conventional generator coil that does produce on-load induced electromagnetic resistance.
Conventional Generator and ReGenX Generator Efficiency Calculations - Reaction to Creation:
1) An electric generator is a machine that converts Mechanical Drive Shaft Power to Electrical Power
2) Mechanical Drive Shaft Power = Torque x Speed
3) Any drive shaft that is at Equilibrium has zero power in it and can do no work.
4) Power is the rate of doing work.
5) Equilibrium occurs at any Steady State such as a standstill or at any steady state rotating speed (no acceleration or deceleration).
6) A drive shaft that is accelerating has a Positive Net Torque.
7) A drive shaft that is decelerating has a Negative Net Torque.
8) A drive shaft that is rotating at a steady state speed is at Equilibrium and can do no work (apparently ;-)
9) A drive shaft that is rotating at a steady state speed when used with a conventional electric generator can only produce electric power if the mechanical input to the generator is increased when the generator is placed on-load.
10) A generator that delivers 9 Watts of electric power to a load with a 10 Watt mechanical input power increase is converting mechanical to electrical power at a 90 % conversion efficiency.
Conventional Generator Efficiency = Output / Input x 100
= 9 / 10 x 100 = 90 %
10a) A conventional generator requires this extra mechanical input power when placed on-load to counteract the conventional generator's conversion of the magnetic field energy that is created around every current bearing wire inside the generator to a counter-electromotive-torque which does work opposing and decelerating the drive shaft's rotation.
This magnetic field Energy that is created, creates Torque and does Work according to the Work Energy Principle is sadly ignored by science and every physicist and engineering student in history simply because it is going in the wrong direction.
11) The ReGenX Generator delivers 60 Watts of electric power to a load with a 0 Watt mechanical input power increase and is converting 0 Watts of mechanical input power to electric power at an infinite % conversion efficiency.
ReGenX Generator Efficiency = 60 / 0 x 100 = Infinite %
11a) The ReGenX Generator requires no extra mechanical input power when placed on-load and the magnetic field energy that is created around every current bearing wire inside the generator creates a complementary-electromotive-torque which does work accelerating the drive shaft's rotation. This magnetic field Energy that is created, creates Torque and does Work is still sadly ignored by science because it proves that energy CAN be created.
Kind regards
Thane
Thane C. Heins
President & CEO
Potential +/- Difference Inc. R & D
"We generate solutions"
Email: thaneh@potentialdifference.ca
