Old 11-13-2015, 10:24 PM
Stealth Stealth is offline
Silver Member
A framework of pipe and several barrels or buckets cut in half lengthwise and provide all the power you need. Many sizes are available as are low RPM 12 volt DC motors*turn backwards). Belts and pulleys or chains and gears can provide needed RPM for you low RPM motor. Automotive bearings can run maintenance free for many years. Anyway the wind blows can turn this turbine. You could use an automotive type voltage regulator to prevent overcharging, and charge many batteries if needed to run you entire house or several smaller turbines for barns, workshops or other outbuildings. Good luck. stealth
