Old 10-14-2015, 10:47 PM
sprocket sprocket is offline
Senior Member
Originally Posted by etherflow View Post
the big wheel will actually be a shaft
Etherflow, if this works as you think, what percentage of a single 360 degree rotation should the device experience a 'forward' thrust? I presume the math can tell you that. I'm thinking about the CIP, if it really has a 98% propulsion efficiency, that would mean that nearly all of the rotational energy is being converted into forward momentum. Or does your idea only work in 'pulsed-mode', where during only a percentage of a 360 degrees would the device experience a forward momentum? Of course if that was the case, wouldn't action/reaction come into play? Fascinating nevertheless, especially since reading about the CIP.
