Old 10-13-2015, 01:26 PM
etherflow etherflow is offline
Junior Member
you forgot two half cycles have the same length in time.
it will rotate faster when far from axis. so, w does not
stay the same due to counterrotation of the half-flywheel.
half-flywheel has higher angular velocity when crossings the
longer path in the SAME time, that is, in other half of the cycle
when travelling near the rim. so, due to this geometry, no external
force is needed to gain apparently free energy and a net force.
Originally Posted by Ernst View Post
You are forgetting that when most of the mass is far from the axis, the whole will rotate slower than when it is near to the axis. THAT is "the LAW". Otherwise there would be an increase of energy in the system when the mass is at the far end.
Remember the orbital velocity is wr (w being the angular velocity), then the kinetic energy is mv/2 becomes mwr/2. So when r increases while w remains constant, the kinetic energy increases.
Thus, to keep a constant velocity you must add energy when the mass-centre to axis distance increases, and you must put a break on it when this distance decreases.
This externally REQUIRED force is the force that you thought to get for free....
Nice try though!
Ernst.
