Old 08-30-2015, 03:46 PM
med.3012's Avatar
med.3012 med.3012 is online now
Gold Member
Originally Posted by John.K1 View Post
Hi Med.
I just think about the ODD harmonics in the Parallel LC contour ( 3,5,.etc).
From the other build I remember the ODD harmonics are "destructive" in the system while EVEN harmonics are Aditive?
HI John.
i only tested the square wave using the output from NE555 oscillator, using the scope i only achieved 24khz as max frequency even thought NE555 may achieve 200 khz very easy!!! the circuit i built is variable frequency/duty , the capacitor used to set the frequency is 10nf , so i think the chip is very old.
i achieved the mini resonance using normal parallel L/C in low voltage mode using these generated square wave, i remember i got two point of resonance, the amplitude will vary also as you know, in the scope the output wave was stable, i think this is good, i am planning to apply HV square wave on the E-TBC, but the problem is the low frequency i got !
